HP Envy x360 15-bp143cl Touchpad Replacement
  1. HP Envy x360 15-bp143cl Touchpad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Touchpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Touchpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Touchpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy x360 15-bp143cl Touchpad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver (PH1) to remove the seven 4mm screws indicated by the gray arrows on the battery.
  6. HP Envy x360 15-bp143cl Touchpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery from the connecting port and lift to remove it from the laptop.
  7. HP Envy x360 15-bp143cl Touchpad Replacement, Touchpad: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy x360 15-bp143cl Touchpad Replacement, Touchpad: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to peel the silver tape near the top right side of the touch pad.
  8. HP Envy x360 15-bp143cl Touchpad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy x360 15-bp143cl Touchpad Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 4mm screws securing the bottom metal bar.
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the three 1mm screws securing the top of the touch pad.
  9. HP Envy x360 15-bp143cl Touchpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal cover by lifting it away from the laptop.
  10. HP Envy x360 15-bp143cl Touchpad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy x360 15-bp143cl Touchpad Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the bottom side of the touch pad.
    • Lift the black tab that secures the touch pad connecting cable to the laptop.
    • Pull the cable from the touch pad connecting port.
  11. HP Envy x360 15-bp143cl Touchpad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy x360 15-bp143cl Touchpad Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the touch pad to remove it.
Spencer Berkins
crwdns2935283:010/10/19crwdne2935283:0
577 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S12-G3, Regan Fall 2019 crwdns2935289:0Cal Poly, Team S12-G3, Regan Fall 2019crwdne2935289:0
CPSU-REGAN-F19S12G3
Thanks now have to find one on E-bay….or?
Michael - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,854
