This guide demonstrates how to properly remove the RAM of a HP Envy m6-n010dx.
Find the battery removal slider.
Slide it across while simultaneously popping out and removing the device's battery.
Remove the five marked screws found under the battery using a philips head screwdriver.
Remove the small panel on the back by prying it off. This should reveal the hard drive.
Gently pry off the cover to release the cable.
Slowly lift the hard drive out and away from the device.
Remove the highlighted screws
Pry off the lower two grip pads
Remove the two additional screws underneath the lower grip pads
Remove the large back panel to reveal the inner workings
Pull back the black rectangular cover to reveal the RAM
Unclip the metal restraints on the side to pop out the RAM
Repeat the previous step for the second RAM below
