There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
Next, use a size PH1 Philips head screw driver to remove the screws.
Then, use a prying tool to help uncouple the backplate.
Finally, use both hands to lift up and take off the back plate of the computer.
Remove the two screws holding the speaker in place.
Once the screws have been removed, gently lift the speaker straight up, but just enough to dislodge it.
Once the speaker is dislodged, gently pull the connecting cable from the sound card.
The speaker is now fully removed and ready to be replaced.
