To gain access to the inside of the laptop, you will first need to remove the back plate. Make sure you have a PH1 size screwdriver to unscrew all of the screws.
There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
Next, use a size PH1 Philips head screw driver to remove the screws.
Then, use a prying tool to help uncouple the backplate.
Finally, use both hands to lift up and take off the back plate of the computer.
