HP Envy m6-1225dx TouchPad Buttons Replacement
  1. HP Envy m6-1225dx TouchPad Buttons Replacement, Optical Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over onto it's top with the back facing you
  2. HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the slide release tab to the left to free the battery.
    • Once the slide release is all the way over, a red icon should be visible.
    • As you pull the tab, the bottom edge of the battery should start to come up.
  3. HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery
  4. HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the center screw using a Phillips #1 screwdriver.
  5. HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Move the battery slide release latch to the side while pulling the service cover forward.
    • Pull the service cover straight up and out to remove.
  6. HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the single screw holding the optical drive
  7. HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to apply pressure to the tab, while simultaneously pulling out the optical drive.
    • While the images show the tab being pushed out with a screwdriver, we recommend using an ESD-safe instrument instead!
  8. HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the optical drive out of the base of the laptop.
  9. HP Envy m6-1225dx TouchPad Buttons Replacement, TouchPad Buttons: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy m6-1225dx TouchPad Buttons Replacement, TouchPad Buttons: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 screws from the hard drive bracket with a Phillips #1 screwdriver.
  10. HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the cable from the side of the hard drive and move it to the side
    • Remove the hard drive from the laptop.
    • Our laptop did not have a hard drive when we disassembled it.
  11. HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws that secure the keyboard to the laptop using a Phillips #1 screwdriver.
  12. HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the laptop onto its left side with it open.
    • Turn the laptop and look into the empty battery slot for two release holes.
    • Insert a metal spudger into the release holes and apply pressure to the back of the keyboard till it comes loose of the laptop.
  13. HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the keyboard away from the laptop.
    • Remove the cable connection from the base of the laptop.
    • Remove the keyboard backlight cable.
    • The keyboard backlight cable is only present on select models.
  14. HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 13 screws on the bottom of the laptop using a Phillips #1 screwdriver.
  15. HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the power button board cable using a pair of tweezers.
    • Disconnect the touchpad button board cable using tweezers.
    • Disconnect the fingerprint reader board cable using tweezers.
    • Disconnect the right speaker cable using tweezers.
    • Remove the 4 screws using a Phillips #1 screwdriver.
    • Apply force to the base of the cover to pop if off from the laptop base.
    • Be sure the cable for the right speaker doesn't get caught on the cover as it is removed or the speaker could be damaged.
  16. HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy m6-1225dx TouchPad Buttons Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the top cover with the touchpad area facing you.
    • Remove the one screw holding the touchpad buttons down with a Phillips #1 screwdriver.
    • Disconnect the cable holding the touchpad buttons to the top cover
Lucas Nelson
crwdns2935283:001/30/20crwdne2935283:0
581 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S14-G3, Lamothe Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S14-G3, Lamothe Spring 2020crwdne2935289:0
ERAU-LAMOTHE-S20S14G3
crwdns2942667:0crwdne2942667:0 446
