HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement
  1. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure that the device is turned off and that all external devices are removed.
  2. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device over so that the back plate is facing upwards.
  3. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a small (size 0) Phillips head screwdriver, remove the twelve 5.5 mm external Phillips head screws that connect the back plate to the device.
    • Make sure to set the screws aside in a safe place so that you do not lose them, as they will be needed to reattach the backplate later.
  4. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, gently pry off the back plate from the device.
  5. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The large black box with the white warning images is the battery.
    • Move the ribbon cable so that it is no longer on top of the battery.
  6. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a small (size 0) Phillips head screwdriver, remove the three 3.5 mm Phillips head internal screws that hold the battery in place.
    • Make sure not to lose these internal screws; they will later be used to reattach the battery.
  7. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the battery and remove it from the slot as shown.
  8. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to disconnect the battery cable.
  9. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the battery and remove it from the device.
  10. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement, Bluetooth Module: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement, Bluetooth Module: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tape holding the power connector cable and loosen the cable from the routing channel to gain access to the bluetooth module.
  11. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of small needle nose pliers or tweezers to disconnect the antenna of the bluetooth module.
  12. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a #0 Phillips head screwdriver, remove the two 3 mm size 0 screws securing the Bluetooth module in place.
  13. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the bluetooth module by its sides and remove it from the computer by wiggling gently. Then place the bluetooth module in an anti-static bag.
Michael Horton
crwdns2935283:010/17/18crwdne2935283:0
130 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G3, Valliere Fall 2018 crwdns2935289:0UMass Dartmouth, Team S1-G3, Valliere Fall 2018crwdne2935289:0
UMASSD-VALLIERE-F18S1G3
crwdns2942667:0crwdne2942667:0 493
