You should replace your solid state drive if it has become damaged or corrupted. The OS will not boot properly is a major system of this.
Press the battery release tab and the battery will pop up.
Remove the battery from the laptop, it will come out easily.
Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
Remove the PM 2.0x2.5 screw with the PH#0 Screwdriver attachment that is shown at the corner of the Solid State Drive.
After you have removed the screw, the Solid State Drive should lift up.
Very carefully, remove the SSD by gently pulling away from the SSD socket.
Please what type of ssd is that and can i get the specifications? I want to get one for my laptop since it didn’t ship with it. Its the same as the one above. HP ENVY TS 15 Notebook PC Thanks.
Wht type of ssd i can insert here
Plz help me
Kavindra Danushka Rajapaksha - crwdns2934203:0crwdne2934203:0
