Use this guide to replace the digitizer screen on an HP Envy 15 TouchSmart. You may need to replace the digitizer if the laptop no longer detects touch or if the glass has cracked or shattered.
Lay the laptop down with the bottom facing up.
Slide the switch to release the battery and remove it.
Remove the screw from the access panel. Gently lift and remove the panel.
Remove the hard drive and disconnect its ribbon cable from both the hard drive and the motherboard.
Gently pry up on black ribbon clank then slide ribbon off motherboard
Remove the screws to loosen the bottom casing.
Remove the two feet to reveal the screws underneath.
Gently pry the edges to loosen the case.
Once loose, lift and remove the plastic casing to reveal the motherboard.
Lift and detach the wireless antenna cables.
Lift and de-route the wires from their tracks until you reach the display hinges.
Detach the two cables. Lift the tab for the ribbon cable before pulling it out.
Remove the screws from each hinge.
Lift the hinges with pliers until they are perpendicular to the case.
Lift and remove the bottom of the laptop from the screen.
Lift the tabs in both the bottom corners and remove the screws beneath.
Using a pry tool as necessary, remove the digitizer from the rest of the screen panel. Be careful around the top edge as there are delicate components beneath.
Forgot to mention disconnecting the wire from the digitizer to the screen.
Using a heat gun, carefully loosen the adhesive connecting the digitizer to its plastic border.
Gently peel the digitizer away from the plastic border.
crwdns2935229:05crwdne2935229:0
These directions are perfect. I was able to successfully change my digitizer in under an hour
where do you get the digitizer?
Amazing,
My name is Nevelson, I have exactly same laptop and mine also is broke, but I don't know where to get the replacement; only the sensor, please I need help and willing to pay handsomely.
Nevelson, I have updated this page to included a link to the part on amazon.
