This guide will help you in replacing the touchpad on your HP Envy Sleekbook m6-k010dx. Make sure to turn the device off before doing anything.
Remove the twelve 9 mm Phillips #00 screws.
Use the plastic opening tool and your hands to remove the bottom cover.
Disconnect the battery power cable from the motherboard.
Remove the six 6 mm Phillips #00 screws from the battery.
Lift the white tab on the ZIF connector to unlock the ribbon cable.
Pull the ribbon cable out of the ZIF connector.
Remove the seven 3mm Phillips #00 screws from the trackpad.
Use the plastic opening tool to lift the touchpad up and pull out to remove.
