Many user have problems with their computer over heating and that is due to a faulty fan or one that is clogged up. If you don't want to replace it and think it only needs to be cleaned you can simply remove it and clean it with computer duster.
            Lay the device face down to begin.
            Slide the release mechanism to the left to release the battery.
            Using a Phillips #1, remove the 8 10.6mm screws.
            Also using a Phillips #1, remove the 8.6mm screw.
            Slide the center panel down to remove it.
            Using a Phillips #1, remove the 3.5mm screw.
            Using a Phillips #1, remove the four 10.6mm screws.
            Pull the disk drive out to remove it.
            Using a Phillips #1, remove the two 2.4mm screws.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Flip the black tab up on the clamp that holds the ribbon cable in place.
            Pull the cable back with your fingers or a pair of tweezers.
            Flip the computer back over
            Use the plastic opening tool to pry the keyboard up .
            Carefully lift the keyboard up.
            Flip up the black tab holding the large ribbon cable down.
            Push both sides of the small white tab forward to release the small ribbon cable.
            Pull both the cables out to remove them.
            Remove the keyboard.
            Flip the small white tab up to release the ribbon cable.
            Pull to remove.
            Repeat the same steps for the other cable.
            Using a Phillips #1, remove the four 5.6mm silver screws.
            Use the plastic opening tool to pry the face plate off the rest of the frame.
            Once you pry all of the snaps up lift the face plate off.
            Using a Phillips #1, remove the two 10.6 mm screws.
            Gently pull back on on the cable to unplug it.
