HP Envy Battery Replacement
Connor French
crwdns2944107:0crwdnd2944107:0Connor Frenchcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:011crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Sun 31, 2022crwdne2944111:0
crwdns2931287:045crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
Has your battery seemingly died far earlier than expected in your HP Envy 15 x360 laptop? This guide will show you how to fix a common cause of a dead battery.
crwdns2944105:0crwdne2944105:0
  1. HP Envy Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Plug in your computer to charge and take a look at the light coming from near the charging port.
    • If the light is a steady orange or white, your computer should be charging normally and this guide is no longer necessary.
    • If the light is a blinking white, your computer is not charging properly and you should proceed to the next step.
  2. HP Envy Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over on its back and remove the two depressed stickers in the middle to reveal the two central 6.0 mm Phillips-head screws.
    WARNING: There are two more screws to be removed! They are located under the rubber feet in back, by the hinges. Peel off the feet to expose the screws, and then unscrew them.
    I learned about them from this article, after spending 10 minutes trying to get the back corner free.
    https://support.hp.com/us-en/document/c0...
    James Grove - crwdns2934203:0crwdne2934203:0
  3. HP Envy Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to pry up the two rear feet near the hinge.
    • You don't need to pry up the two feet near the front of the laptop as there are no screws underneath them.
  4. HP Envy Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver to remove the 14 screws securing the back cover.
  5. HP Envy Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once all of the screws have come out, flip the laptop over and open the lid so that the keyboard is face up.
    • Pop the keyboard from the sides and carefully lift it off of the parts underneath.
    • DO NOT pull the keyboard away from the rest of the laptop too quickly. There are various cords and wires connecting the keyboard section to the rest of the computer that should remain plugged in.
  6. HP Envy Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lay the keyboard section against the open screen of your laptop without unplugging anything.
    • Check the inside of your laptop to make sure there are no glaringly obvious problems (insects, missing parts, scorched parts).
  7. HP Envy Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the battery and the three 4.0 mm Phillips-head screws that hold it in place.
    • Unscrew these three screws and use the tab attached to the battery to remove it safely from the laptop.
    • Unplug the cord attaching the battery to the motherboard. This is the only cord that should be unplugged throughout the entire fix.
  8. HP Envy Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the battery is safely removed, plug the charging cord into the charging port on the side and plug the other end into the wall.
    • DO NOT turn the computer on or touch any of the internal components during this step.
    • If the light is on after plugging it in, you have just confirmed that something is wrong with the battery, which means you're on the right track!
    • If the light on the side blinks upon plugging it in, the battery is not the problem. If that is the case, put your laptop back together and consult an expert.
    • Unplug the charging cable.
  9. HP Envy Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy Battery Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the battery back where it was previously and find where it was plugged in.
    • Due to general wear and tear, often this will become slightly unplugged, causing the laptop to fail to charge properly.
    • Plug the cable on the battery back into the port on the motherboard and make sure it is secured.
  10. HP Envy Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Run the earlier test from Step 7 that you performed on the laptop with the battery inside.
    • If the light comes on and doesn't blink, you have fixed the problem! Congratulations!
    • If the light still blinks, you may have to purchase a new battery for your laptop.
crwdns2935229:020crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Connor French
crwdns2935283:009/29/15crwdne2935283:0
1.367 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-2, Green Fall 2015 crwdns2935289:0Cal Poly, Team 17-2, Green Fall 2015crwdne2935289:0
CPSU-GREEN-F15S17G2
crwdns2947412:09crwdne2947412:0
In addition to the screws shown there are two screws under the pads close to the hinges. Pry the pads off and remove the screws under them. Then follow the instructions.
Tom D
Tom - crwdns2934203:0crwdne2934203:0
can you tell me the name of the battery ?
عبدالسلام محمد - crwdns2934203:0crwdne2934203:0
Worked like a gem. Now my battery is even charging. There must be a loose connection between the battery and mother board. Double thumbs up to you!
ganesh_sarma478 - crwdns2934203:0crwdne2934203:0
Agree with Tom - I put the comment under the step where the screws are.
Sean C - crwdns2934203:0crwdne2934203:0
This worked like a charm for me. Thank you for posting!! followed directions exactly, so easy to follow. The only trouble I had was getting the keyboard detached. It was really stuck on there, but I eventually got it. Battery is charging as we speak.
julieb6148 - crwdns2934203:0crwdne2934203:0
does the battery need to charge before I can use it. I tried to turn it on right after and it won’t.
cshearrow25 - crwdns2934203:0crwdne2934203:0
I did all of this and replaced the battery no problem. The charging light is a solid white, I charged over night but my power button will not work, after I press it, it will flash once white then nothing! It used to turn on before I replaced the battery, did I do something wrong?
Karen Pina - crwdns2934203:0crwdne2934203:0
Why isnt my keyboard working after i replaced the battery?
Eva Welch - crwdns2934203:0crwdne2934203:0
The light's steady, but the computer tells me when it restarts (doing a bunch of upgrades) that the battery is well, toast. Just another sign you might want to look for. New battery on the way, and this guide is bookmarked for when it comes in! Thanks!
Harriet Engle - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 118
crwdns2942667:0crwdne2942667:0 49,669
