HP Envy 700-030qe Solid State Drive Replacement
  1. HP Envy 700-030qe Solid State Drive Replacement, Solid State Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning, it is good to wear an anti-static wrist band to prevent electrical components from getting harmed.
    • Attach the anti-static wristband to your wrist, and clip the other end to an exposed piece of metal anywhere on the case.
  2. HP Envy 700-030qe Solid State Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start by opening the device case by unscrewing the 10.5mm hand screw on the back of the computer.
    • If the hand screw is too tight, you may use the Torx T15 screwdriver to remove it.
  3. HP Envy 700-030qe Solid State Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the computer onto its side to continue removing the case cover.
    • Slide the cover off by sliding it to the right.
  4. HP Envy 700-030qe Solid State Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy 700-030qe Solid State Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the SSD inside the open case.
    • Unplug the SATA power cable from the hard drive by pulling straight up.
  5. HP Envy 700-030qe Solid State Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finish disconnecting the hard drive by unplugging the black SATA interface cable by pulling up.
  6. HP Envy 700-030qe Solid State Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the SSD and its casing, pull out on the side silver tab.
    • At the same time, pull up on the hard drive. It should slide out smoothly without much effort.
  7. HP Envy 700-030qe Solid State Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To completly remove the SSD from its casing, unscrew the four 5mm screws on opposite ends of the casing. Use a Torx T15 screw driver to accomplish this.
    • Notice that the screws to remove are the four screws inside the holes rather than the screws that are next to the holes.
  8. HP Envy 700-030qe Solid State Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finally, slide the SSD out of the casing.
crwdns2935229:05crwdne2935229:0
Chandler Warne
crwdns2935283:010/01/15crwdne2935283:0
303 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-9, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 5-9, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S5G9
crwdns2942667:0crwdne2942667:0 2,787
