HP Envy 700-030qe CPU Fan Replacement
  1. HP Envy 700-030qe CPU Fan Replacement, CPU Fan: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy 700-030qe CPU Fan Replacement, CPU Fan: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy 700-030qe CPU Fan Replacement, CPU Fan: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
    • Unscrew the 10.5mm screw on the left of the desktop using your hand.
    • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
  2. HP Envy 700-030qe CPU Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy 700-030qe CPU Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next, remove the side panel by sliding it towards the back of the desktop and pulling up, as shown.
  3. HP Envy 700-030qe CPU Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 120mm Phillips #000 head, 5 mm screws holding the fan.
  4. HP Envy 700-030qe CPU Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull up and disconnect the fan's power cable.
  5. HP Envy 700-030qe CPU Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fan by pulling up carefully.
Jessica Resta
crwdns2935283:010/01/15crwdne2935283:0
235 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-9, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 5-9, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S5G9
Im looking to replace the fan in mine, what size would I look for, or even what model would be best?
AzyP Zero - crwdns2934203:0crwdne2934203:0
Did you ever determine what fan to use ? I need to order one for my system.
Dennis - crwdns2934203:0crwdne2934203:0
I bought the Philips #000 Screwdriver from iFixit as listed above. It is not even close to what is needed. That screwdriver is like a jewelers tiny Philips head. It needs a much bigger screwdriver.
Fails to mention the most important part of the entire procedure. That would be to remove the old thermal paste from the top of the CPU with 91-99% isopropyl alcohol and re-apply new thermal paste. Short of doing this almost guarantees failure to maintain proper cooling.
Guy Martin - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,714
