The scanner glass for the HP Envy 5660 may receive cracks over time. This guide will help the user replace the scanner glass.
Open the cartridge access area.
Remove the three 11.5 mm screws with a T10 bit.
Locate the cover hinge on the right side of the printer.
Pull the hinge off of the scanner to allow the scanner to open to 90 degress.
Remove the 12 mm screws on the left side of the printer with a T10 bit.
Remove the 11.5 mm screw with a T10 bit to release the spring-loaded hinge.
Pull the plastic side cover off of the printer.
Remove the five 11.5 mm screws located at the bottom of the scanner.
The top of the scanner will now easily pull off.
Pry the old scanning glass up with a metal spudger.
This procedure also applies to the HP ENVY Photo 7155 !
Remove an additional three 11.5 mm torx head screws in the same plane as step #4 photo, but near the hinges. This allows the cover hinges to be raised a bit for easier access to the screws removed in step #7. It also makes it easier to remove and reinstall the side cover.
My scanner glass was not broken, but inside surface had a dirty haze that was effecting my scans and needed cleaning. Thanks, I was ready to buy a new scanner.
