HP Envy 5660 Scanner Glass Replacement
    1. HP Envy 5660 Scanner Glass Replacement, Scanner Glass: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Open the cartridge access area.
    2. HP Envy 5660 Scanner Glass Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the three 11.5 mm screws with a T10 bit.
    3. HP Envy 5660 Scanner Glass Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy 5660 Scanner Glass Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy 5660 Scanner Glass Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the cover hinge on the right side of the printer.
      • Pull the hinge off of the scanner to allow the scanner to open to 90 degress.
    4. HP Envy 5660 Scanner Glass Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy 5660 Scanner Glass Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the 12 mm screws on the left side of the printer with a T10 bit.
    5. HP Envy 5660 Scanner Glass Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy 5660 Scanner Glass Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the 11.5 mm screw with a T10 bit to release the spring-loaded hinge.
      • Since this is a compression spring, the hinge will snap downwards as soon as it is loosened.
    6. HP Envy 5660 Scanner Glass Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy 5660 Scanner Glass Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy 5660 Scanner Glass Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull the plastic side cover off of the printer.
      • You may need to lift the printer and push the cover downwards as it is latched onto the bottom of the printer.
      • Plastic opening tools or a metal spudger may also be used.
    7. HP Envy 5660 Scanner Glass Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the five 11.5 mm screws located at the bottom of the scanner.
      • Steps 3-6 were intended to create easier access to these screws. However, they will still be difficult to reach.
      • The top of the scanner will now easily pull off.
    8. HP Envy 5660 Scanner Glass Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy 5660 Scanner Glass Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry the old scanning glass up with a metal spudger.
      • There are adhesives under the scanning glass. Be careful not to break the glass while removing it.
Ryan Steakley
crwdns2935283:001/23/18crwdne2935283:0
790 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G6, Livingston Winter 2018 crwdns2935289:0Cal Poly, Team S1-G6, Livingston Winter 2018crwdne2935289:0
CPSU-LIVINGSTON-W18S1G6
Remove an additional three 11.5 mm torx head screws in the same plane as step #4 photo, but near the hinges. This allows the cover hinges to be raised a bit for easier access to the screws removed in step #7. It also makes it easier to remove and reinstall the side cover.
My scanner glass was not broken, but inside surface had a dirty haze that was effecting my scans and needed cleaning. Thanks, I was ready to buy a new scanner.
Rich Monell - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 2,106
