HP Envy 5660 Printhead Replacement
  1. HP Envy 5660 Printhead Replacement, Printhead: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the printer so that the underside of the scanner is showing.
  2. HP Envy 5660 Printhead Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the black 11.5 mm screw closest to the front right corner using a T10 screw bit.
  3. HP Envy 5660 Printhead Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove right side of the printer using a plastic opening tool or metal spudger.
    This is the wrong side of the printer. This grants access to a PCB and ribbon cables.
    Thomas John - crwdns2934203:0crwdne2934203:0
  4. HP Envy 5660 Printhead Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove spring from the side of the print head rail using a metal spudger.
    And remove the E clip. Your instructions come up short.
  5. HP Envy 5660 Printhead Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy 5660 Printhead Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the metal rail the print head rests on inwards to remove it from its bearings.
    You need to remove the E clip first.
  6. HP Envy 5660 Printhead Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the belt from the back of the print head using a metal spudger.
    One needs to remove the print head from the drive gears. These are located under the plastic cover in the background.
    Still zero mention of a ribbon cable.
  7. HP Envy 5660 Printhead Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the print head from the metal rail by sliding it off the rail.
Ryan Steakley
crwdns2935283:001/23/18crwdne2935283:0
781 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G6, Livingston Winter 2018 crwdns2935289:0Cal Poly, Team S1-G6, Livingston Winter 2018crwdne2935289:0
CPSU-LIVINGSTON-W18S1G6
I wouldn't recommend this guide to anyone without prior experience as it's non-thorough and missing many steps. Started with a clogged printhead; finished with a torn ribbon cable and a couple other new damages.
Ryan Steakley's Dad - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 5,842
