HP Envy 5660 LCD Replacement
  1. HP Envy 5660 LCD Replacement, LCD: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the scanner to open up the printer cartridge access area.
  2. HP Envy 5660 LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy 5660 LCD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 12 mm screws with a T10 bit.
  3. HP Envy 5660 LCD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy 5660 LCD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy 5660 LCD Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a metal spudger to pry open the front panel.
    • Work your way all the way around the front panel doing the same.
    • Gently flip the cover over, exposing the motherboard.
    • There will be loud popping sounds when the cover is being separated from the rest of the printer.
  4. HP Envy 5660 LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy 5660 LCD Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 4.5 mm screws from the motherboard with a T6 bit.
    • Gently remove the motherboard from the top of the LCD, but make sure the ribbon cables are still attached.
    • Beware damaging the white ribbon cable.
  5. HP Envy 5660 LCD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy 5660 LCD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 5 mm screws with a T6 bit, allowing you to separate the LCD from the cover,
  6. HP Envy 5660 LCD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the metal spudger underneath the LCD and gently lift up to remove the LCD.
Ryan Steakley
crwdns2935283:001/23/18crwdne2935283:0
790 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G6, Livingston Winter 2018 crwdns2935289:0Cal Poly, Team S1-G6, Livingston Winter 2018crwdne2935289:0
CPSU-LIVINGSTON-W18S1G6
Great description but there is a part needed - the LCD. Is that part available? How do I get it?
Thanks,
PJE
pateckelberry - crwdns2934203:0crwdne2934203:0
Ditto, I'm in the same position, did you ever find the part/LCD replacement screen?
Tessa Robles - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 1,463
