Use this guide to replace the broken display on your HP Envy 4-1105dx.
Unscrew and remove the one 7.5 mm Phillips-head screw using Phillips #1 screwdriver.
Unscrew twelve 6.0 mm Phillips-head screws using Phillips #1 screwdriver.
Use the plastic opening tool (which is short and has a thin end for prying open device parts) to pry open the back case of the device.
Once the device is open, move the ribbon cable to the side.
Use the flat end of a plastic spudger to disconnect the battery cable from its socket in the motherboard.
Unscrew and remove the three 4.0 mm Phillips-head screws that hold the battery in place, using a Phillips #1 screwdriver.
Close the device and turn it right-side up. Locate the two screw covers on the left and right side base of the display panel.
Remove the screw covers, using the black plastic spudger.
Remove the two 3.0 mm Phillips-front screws on the left and right hinges that secure the display panel to the computer, using a Phillips #1 screwdriver.
Pry open the plastic bezel case of the device using the plastic spudger. If the plastic spudger doesn't work, carefully use the metal spudger.
Loosen the edges of the case from all four sides of the display panel.
Once the back case pops out, close the laptop exposing the back display.
Remove the four 4.0 mm Phillips display panel screws using Phillips #1 screwdriver.
Remove the four 2.0 mm Phillips screws using Phillips #00 screwdriver.
Remove the four 4.0 mm Phillips silver screws on the hinges using a Phillips #1 screw driver.
Remove the two 6.0 mm Phillips black hinge cover screws using a Phillips #0 screw driver.
Flip and remove the hinge covers using a plastic spudger.
Disconnect the ribbon cable on the bottom of the display panel using a plastic spudger.
Disconnect the adjacent golden LCD connector using a plastic spudger.
Remove the golden tape adhering to the display panel using a plastic spudger.
Remove the white color wifi antennas from the display panel using a plastic spudger.
Separate the transparent plastic tape that covers the circuit board using hands.
Carefully flip the circuit board.
Remove the black tape adhering to the green circuit board that is connected to the display panel.
Using a plastic prying tool, remove the display panel.
This is the disassembled screen.
