HP Envy 4-1105dx Hard Drive Replacement
    1. HP Envy 4-1105dx  Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Power off the device before beginning disassembly. Disconnect all external devices.
      • Flip the device on its back.
    2. HP Envy 4-1105dx  Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew and remove the one 7.5 mm Phillips-head screw using Phillips #1 screwdriver.
    3. HP Envy 4-1105dx  Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew twelve 6.0 mm Phillips-head screws using Phillips #1 screwdriver.
    4. HP Envy 4-1105dx  Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the plastic opening tool (which is short and has a thin end for prying open device parts) to pry open the back case of the device.
    5. HP Envy 4-1105dx  Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the device is open, move the ribbon cable to the side.
    6. HP Envy 4-1105dx  Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the flat end of a plastic spudger to disconnect the battery cable from its socket in the motherboard.
    7. HP Envy 4-1105dx  Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew and remove the three 4.0 mm Phillips-head screws that hold the battery in place, using a Phillips #1 screwdriver.
    8. HP Envy 4-1105dx  Hard Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the battery up and remove.
      • Removing the battery can dislodge the touchpad bracket. Place the battery carefully over the alignment pins.
    1. HP Envy 4-1105dx  Hard Drive Replacement, Hard Drive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy 4-1105dx  Hard Drive Replacement, Hard Drive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four 4.0 mm screws that hold down the hard drive case using a Philips #1 Screwdriver.
      • Move the hard drive case and hard drive so that you can easily reach the hard drive cable.
    2. HP Envy 4-1105dx  Hard Drive Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy 4-1105dx  Hard Drive Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy 4-1105dx  Hard Drive Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the plastic spudger tool to loosen the hard drive SATA cable connection by pushing it away from the motherboard.
      • Once it is loose, pull the hard drive out of the socket.
      • Remove the hard drive from the device.
    3. HP Envy 4-1105dx  Hard Drive Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy 4-1105dx  Hard Drive Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy 4-1105dx  Hard Drive Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull out the hard drive cable from the hard drive, and set it aside.
      • Remove the four 3.0 mm screws that attach the hard drive case to the hard drive using a Philips #1 Screwdriver. If the screwdriver is too big, try #0 sized screwdriver.
    4. HP Envy 4-1105dx  Hard Drive Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the hard drive from the hard drive case.
KC Armstrong
crwdns2935283:010/03/17crwdne2935283:0
204 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 1,181
