The RAM of the computer allows the computer to manage resources better. This guide will help you replace or upgrade it. You will need a replacement RAM card to complete this guide and replace the current card. You will need is the iFixit Opening Tool, a 00 Phillips-head Screwdriver, and a T5 Torx-Head Screwdriver.
Place the laptop on its back.
Remove the plastic covering to the Disk Reader.
Locate the small hole on the side of the disk reader. Insert the T5 Torx head screwdriver (or device of similar thickness) to release the covering for the disk reader.
Unscrew all visible screws.
Use the T5 Torx Screwdriver and remove the four visible 6.5mm screws on the bottom of the laptop.
One 2.5mm screw, is located where the disk reader was once located. Use a Phillips #00 screwdriver to remove the single screw that connects the bottom cover of the laptop to the bottom frame.
Pry the gripper completely off to expose the two screws.
Remove the 2.5mm screws under the gripper nearest to the hinge using the Phillips #00 screwdriver.
Use the iFixit opening tool to pry off the back cover.
Lift the two tabs on the RAM stick outwards.
Gently lift the RAM out of the socket and remove it from the device.
