HP Elitebook x360 1040 G5 SSD Replacement
  1. HP Elitebook x360 1040 G5 SSD Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elitebook x360 1040 G5 SSD Replacement, Lower Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off device before disassembly.
    • Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
  2. HP Elitebook x360 1040 G5 SSD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elitebook x360 1040 G5 SSD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry open the lower case from where it meets the laptop base.
    • Remove the lower case from the work area.
  3. HP Elitebook x360 1040 G5 SSD Replacement, SSD: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elitebook x360 1040 G5 SSD Replacement, SSD: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elitebook x360 1040 G5 SSD Replacement, SSD: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips 0 screwdriver to remove the 2mm Phillips screws from the SSD assembly.
    • Gently slide the SSD to the right and pull out to remove it from its position within the motherboard.
Corey Agena
crwdns2935283:004/21/19crwdne2935283:0
833 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G4, Maness Spring 2019 crwdns2935289:0Cal Poly, Team S1-G4, Maness Spring 2019crwdne2935289:0
CPSU-MANESS-S19S1G4
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 4,061
