HP Elitebook 8570w Hard Drive Replacement
  1. HP Elitebook 8570w Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To begin, you will need to remove the battery by sliding the left slider (red) to the left.
    • Push the battery away from you to release it.
    • Then, use the right slider to remove the computer's backing (shown in image)
    • Slide the backing towards you to remove it.
  2. HP Elitebook 8570w Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the backing has been removed, you will be able to locate the computer's hard drive in the bottom left corner.
  3. HP Elitebook 8570w Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the hard drive compartment's cover, unscrew the two 0.8mm Phillips screws with a P1 Phillips-head screwdriver.
    • Open by lifting the left side of the cover so it is facing upwards and outwards.
    • The black screws, not the gold screws.
  4. HP Elitebook 8570w Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the same screwdriver to loosen all three screws at the attachment points of the silver hard drive caddy.
    • These screws do not need to be completely removed.
  5. HP Elitebook 8570w Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the caddy and gain access to the hard drive, pull the black tab up to release it from the caddy.
    • Once you can grab the tab with your fingers, pull it to the left to disconnect the hard drive from the computer.
  6. HP Elitebook 8570w Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The hard drive can now be replaced inside the caddy.
crwdns2935229:05crwdne2935229:0
MJ Routh
crwdns2935283:011/06/17crwdne2935283:0
465 crwdns2915208:0crwdne2915208:0
Baylor, Team S8-G5, Johnson Fall 2017 crwdns2935289:0Baylor, Team S8-G5, Johnson Fall 2017crwdne2935289:0
BU-JOHNSON-F17S8G5
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 15,339
