Use this guide to replace the internal speaker assembly if the speakers are known to be blown on your HP Elitebook 8460p.
This guide requires disassembling a large part of the laptop and will take a longer period of time. Make sure to keep track of all the components and screws that must be removed. This guide also requires removing the chassis of the laptop which involves pry tools. Complete each step slowly and carefully to avoid breaking any plastic components.
Ground yourself with the ESD strap to prevent electrostatic discharges from damaging any of the components that must be removed or the motherboard.
To complete this guide, you will need a Phillips #0 screw driver, a T2 Torx screw driver, a plastic pry tool, and an ESD strap.
On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
Slide the battery away from the switches until it can be lifted away from the laptop.
Lift the battery away from the laptop.
On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
Slide the back shell of the laptop away from the switches until it can be lifted up.
Lift the shell straight up.
Using a Phillips #0 bit, unscrew the two screws on opposite corners of the fan.
Pull the fan straight up and to the side slightly.
Disconnect the small electrical connector. Pry the edge up with your finger nails or using a small plastic pry tool.
Using a Phillips #0 bit, unscrew the six screws on the heat sink.
Pry the inside edge up, pulling the entire assembly to the inside of the laptop, exposing the processor and graphics processor
Blow compressed air through the vent from the outside and through the heat sink.
Using a Phillips #0 bit, unscrew the one Phillips head screw.
Using a T2 Torx screwdriver, remove the two 8.0mm Torx screws.
With your fingernail, pry the edge of the optical drive away from the chassis of the laptop and pull it straight out.
Using a small paper clip, push the paper clip straight in to open the optical drive.
Using a small point, pop the tab out.
Rotate the plastic cover clockwise to release the tab on the left hand side of the optical drive.
Pull the tab with the small engraved arrow up and towards the inside of the laptop.
Using a Phillips #0 bit, unscrew the three screws that hold the hard drive assembly in place.
Remove the silver metal cover by pulling straight up on the black tab.
Disconnect the hard drive by pulling the drive straight out to the left.
Using a Phillips #0 screwdriver, remove the two 3.0mm screws holding the speaker assembly in place.
Grasping one corner with two fingers, lift the speaker assembly up and out of the laptop.
Using a T2 Torx screwdriver, remove the six 8.0mm Torx screws.
Using a Phillips #0 screwdriver, unscrew the Phillips screw next to the fan assembly.
Using a Philips #0 screwdriver, unscrew the two Phillips screws next to the battery.
Using a Phillips #0 screwdriver, remove the three 2.0mm Phillips screws underneath the battery.
Using a Phillips #0 screwdriver, remove the two 3.0mm Phillips screws to the right of the optical drive slot
Using a Phillips #0 screwdriver, remove the two 2.0mm Phillips screws underneath the hard drive assembly.
Using a T2 Torx screwdriver, remove the four 8.0mm Torx screws on the back side of the laptop.
Using a spudger, work your way around the edge of the laptop popping the plastic chassis up.
Lift the chassis up and detach the small connector between the hard drive and heat sink.
Disconnect the speaker connector from the motherboard.
Remove the old speaker assembly and connect the wire for the new speaker assembly in the same location.
Thanks for the tutorial. I skipped step 11 - 29 and just cut the wire of the old speakers on both ends. Put in the new speaker and hid the wire under the lid of the hard drive. Looking back.. I could have done this straight away after step 5. Removing the fan and heat sinc isn't necessary if onne's going to cut the wire. Nevertheless, taking out the fan was good to remove all the dust in front of the outlet.
Thanks again!
Thanks for your idea..I have searching easy way for it 🙏
what if it does not work,what does that mean?
julia melrose - crwdns2934203:0crwdne2934203:0
