HP Elitebook 8460p Speaker Assembly Replacement
  1. HP Elitebook 8460p Speaker Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
    what if it does not work,what does that mean?
    julia melrose - crwdns2934203:0crwdne2934203:0
  2. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Speaker Assembly Replacement, Back Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Speaker Assembly Replacement, CPU Cooling Fan: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement, CPU Cooling Fan: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Attach an ESD strap to your wrist and to a ground.
    • Using a Phillips #0 bit, unscrew the two screws on opposite corners of the fan.
  6. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the fan straight up and to the side slightly.
  7. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the small electrical connector. Pry the edge up with your finger nails or using a small plastic pry tool.
  8. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #0 bit, unscrew the six screws on the heat sink.
  9. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the inside edge up, pulling the entire assembly to the inside of the laptop, exposing the processor and graphics processor
    • Clean and replace the thermal paste on the processor if you have any thermal paste.
  10. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Blow compressed air through the vent from the outside and through the heat sink.
  11. HP Elitebook 8460p Speaker Assembly Replacement, Optical Drive: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement, Optical Drive: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement, Optical Drive: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #0 bit, unscrew the one Phillips head screw.
    • Using a T2 Torx screwdriver, remove the two 8.0mm Torx screws.
  12. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With your fingernail, pry the edge of the optical drive away from the chassis of the laptop and pull it straight out.
  13. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Skip this step if you are removing the optical drive to fix or replace a different component in the laptop.
    • Using a small paper clip, push the paper clip straight in to open the optical drive.
  14. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a small point, pop the tab out.
    • Rotate the plastic cover clockwise to release the tab on the left hand side of the optical drive.
  15. HP Elitebook 8460p Speaker Assembly Replacement, Hard Drive: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement, Hard Drive: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the tab with the small engraved arrow up and towards the inside of the laptop.
  16. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #0 bit, unscrew the three screws that hold the hard drive assembly in place.
  17. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the silver metal cover by pulling straight up on the black tab.
  18. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the hard drive by pulling the drive straight out to the left.
    • If replacing the hard drive, seat the new hard drive firmly in the connector.
  19. HP Elitebook 8460p Speaker Assembly Replacement, Speaker Assembly: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement, Speaker Assembly: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the two 3.0mm screws holding the speaker assembly in place.
  20. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasping one corner with two fingers, lift the speaker assembly up and out of the laptop.
  21. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a T2 Torx screwdriver, remove the six 8.0mm Torx screws.
    • Four of the Torx screws are located on the four corners of the laptop and the other two are next to the hard drive assembly.
  22. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #0 screwdriver, unscrew the Phillips screw next to the fan assembly.
  23. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Philips #0 screwdriver, unscrew the two Phillips screws next to the battery.
  24. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the three 2.0mm Phillips screws underneath the battery.
  25. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the two 3.0mm Phillips screws to the right of the optical drive slot
  26. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the two 2.0mm Phillips screws underneath the hard drive assembly.
  27. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a T2 Torx screwdriver, remove the four 8.0mm Torx screws on the back side of the laptop.
  28. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, work your way around the edge of the laptop popping the plastic chassis up.
  29. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the chassis up and detach the small connector between the hard drive and heat sink.
  30. HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elitebook 8460p Speaker Assembly Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the speaker connector from the motherboard.
    • Remove the old speaker assembly and connect the wire for the new speaker assembly in the same location.
Garrett Anderson
crwdns2935283:009/16/19crwdne2935283:0
2.250 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S12-G1, Lamothe Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S12-G1, Lamothe Fall 2019crwdne2935289:0
ERAU-LAMOTHE-F19S12G1
Thanks for the tutorial. I skipped step 11 - 29 and just cut the wire of the old speakers on both ends. Put in the new speaker and hid the wire under the lid of the hard drive. Looking back.. I could have done this straight away after step 5. Removing the fan and heat sinc isn't necessary if onne's going to cut the wire. Nevertheless, taking out the fan was good to remove all the dust in front of the outlet.
Thanks again!
JJJJJJJJJJJ - crwdns2934203:0crwdne2934203:0
Thanks for your idea..I have searching easy way for it 🙏
Muditha Mahanama -
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 5,587
