crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Slide the latch, to the right, away from the lock symbol.
Slide the cover away from the latch to remove it.
Once the cover is removed you will be able to see the battery and the two latches that hold it in place.
The two latches should be pulled back, one of which is spring loaded and must be held in place in order to remove the battery.
Battery should easily be lifted up and out.
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.16-
Identify the RAM and the pull tabs that will be used in the next step.
Pull back the two tabs on either side of the RAM this will allow the RAM to be removed.
Pull the RAM stick gently out and up once the tabs have been pulled to the side.
Loosen the four Phillips screws securing the hard drive.
Grab the pull tab on the hard drives plastic casing and pull it out and to the side.
Remove the 2.5" hard drive from the plastic bracket.
In order to take out the fan and heatsink the plastic cover must first be taken off.
Remove the eight 2 mm Phillips #1 screws.
Remove the thirteen 6 mm Torx T8 screws.
Remove the five Torx M2.5x5 screws.
Remove the single 7 mm Phillips #1 screw.
Loosen the two Phillips #1 screws. These screws will remain captive to the device.
Using the plastic opening tools, remove the plastic cover by beginning at one of the corners and prying it up.
Use the plastic opening tools to remove the keyboard, starting at one of the top corners. You need to lift the top side and then takeing it out moving the keyboard towards the screen.
Once the keyboard is removed, detach the ribbons connecting the keyboard to the laptop by prying the small tab and sliding the ribbon out.
Loosen the six Phillips #1 screws. These will remain captive to the heatsink.
Use the plastic opening tools to remove the tape covering the wires connected from the fan to the motherboard.
Disconnect the fan by sliding the wire out.
Remove the fan by lifting it up and sliding it out.
Remove the heat sink by lifting it up and sliding it out.
crwdns2935229:016crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Quality guide. Very logical. Thank you.
perfectly done, thank you!
Do you need to remove the keyboard for replacing the tehmal paste?
You don’t need to remove the keyoard to replace the thermal paste :)
Brendan -
Merci beaucoup pour ce tutoriel. Vous avez fait du très bon travail, permettant à d'autres d'effectuer ce travail délicat. Merci encore
