HP Elitebook 830 G7 or G8 Top Cover replacement
  1. HP Elitebook 830 G7 or G8 Top Cover replacement, Remove the Base Enclosure: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the notebook.
    • Unscrew the screws.
    • Open the base enclosure using a plastic wedge (a credit card might also work). Follow the direction of the green arrows.
  2. HP Elitebook 830 G7 or G8 Top Cover replacement, Remove battery and motherboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elitebook 830 G7 or G8 Top Cover replacement, Remove battery and motherboard: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elitebook 830 G7 or G8 Top Cover replacement, Remove battery and motherboard: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach the battery using a plastic spudger.
    • Unscrew the battery screws. Be aware not to damage the speaker cables.
    • Now remove the CMOS battery. Beware: it is glued to the enclosure. So remove with care.
    • Remove the SIM slot.
    • Now detach all connections with the mother board (using a plastic spudger). Unscrew the black (mostly flat) screws until the mother board is loose.
    • Put the Display Cables to the top side. In that way the cables aren't damaged when removing the top cover.
    • Remove the loose plastic parts on the motherboard.
  3. HP Elitebook 830 G7 or G8 Top Cover replacement, Remove Top Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elitebook 830 G7 or G8 Top Cover replacement, Remove Top Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the mother board.
    • Unscrew all the remaining components from the top cover.
    • Unscrew the black screws in the top corners until you can separate the top cover and the display.
  4. HP Elitebook 830 G7 or G8 Top Cover replacement, Re-assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elitebook 830 G7 or G8 Top Cover replacement, Re-assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Attach the new Top Cover.
    • Follow the previous steps in reverse order.
    • Beware when closing the Base Enclosure: slide it towards the front at a 30 degree angle until it snaps in place. Screw everything back together. In this way you prevent an open gap at the front side.
To replace the top cover/keyboard, the device needs to be completely disassembled. That takes time but is not that difficult.
crwdns2934873:0crwdne2934873:0
nl en
100%
crwdns2934883:0Marelec ITcrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2935103:0crwdne2935103:0
Marelec IT
crwdns2935283:003/15/19crwdne2935283:0
219 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 112
crwdns2942667:0crwdne2942667:0 4,273
