The RAM, also known as the Random Access Memory, is a hardware memory built into computers for short-term memory. If you are experiencing difficulties with web pages, folders, or programs loading extremely slow then here is the step-by-step guide to replacing the RAM storage within your HP Elitebook 820 G2. Ensure that you proceed with caution when moving the fragile chips to the side when accessing the RAM during disassembly.
Slide the lever firmly to the left on the back panel.
Slide the back panel towards you.
Lift the back panel to remove it.
Undo the clips on the sides of the RAM chips by pushing them away from the RAM.
Once the clips are unfastened, use a plastic spudger to lightly pry up the RAM chips.
Grab the RAM chips, remove them, and set them aside.
Hi KaitLyn Teubert
Thank you for your HP Elitebook 820 G2 RAM Replacement tutorial
Currently, I have 2 HP Elitebook 820 G2 notebook, and I have problem with one of my HP Elitebook 820 G2.
RAM is not detected. I have tried to replace the RAM to another HP Elitebook 820 G2, and also buy new RAM but its doesn't work at all.
May you have any suggestion to my problem?
Thank you.
Jaya Ma - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
