HP Elitebook 2740p Screen Replacement
    1. HP Elitebook 2740p Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the lock tab to the right.
    2. HP Elitebook 2740p Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift and remove the battery from the battery compartment.
    1. HP Elitebook 2740p Screen Replacement, Screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elitebook 2740p Screen Replacement, Screen: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elitebook 2740p Screen Replacement, Screen: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the radio antenna on the right side of the top edge of the screen. Slide the latch to release the antenna.
      • Use a Phillips #0 screwdriver to remove the two 4 mm screws recessed in the antenna housing.
    2. HP Elitebook 2740p Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elitebook 2740p Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elitebook 2740p Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a metal spudger to separate bezel from laptop body. there are tabs holding the bezel on along the entire bezel.
      • Pay special attention to the hinge cover at the bottom. It has tabs at both the top and bottom.
      • Remove the bezel from the laptop.
    3. HP Elitebook 2740p Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elitebook 2740p Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elitebook 2740p Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Phillips #0 screwdriver to remove the eight 4 mm screws that hold the frame of the screen in place.
      • Use a Phillips #00 screwdriver to remove the single 3 mm screw at the corner of the frame.
    4. HP Elitebook 2740p Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elitebook 2740p Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elitebook 2740p Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Phillips #0 screwdriver to remove the two 4 mm screws that hold the tilt button in place.
      • Remove the tilt button.
    5. HP Elitebook 2740p Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elitebook 2740p Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elitebook 2740p Screen Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Phillips #0 screwdriver to remove the three screws that secure the tablet-mode button board.
      • Disconnect the two blue ribbon cables and gently pull them free.
      • Remove the PCB board from the screen housing.
    6. HP Elitebook 2740p Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elitebook 2740p Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elitebook 2740p Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the gray rubber pad at the top of the screen next to the camera.
      • Remove the 3mm screw with a Phillips #0 screwdriver
      • Carefully tilt the screen down onto the keayboard
    7. HP Elitebook 2740p Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elitebook 2740p Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Fold the protective foil back from the ribbon cables.
    8. HP Elitebook 2740p Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elitebook 2740p Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elitebook 2740p Screen Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unseat display ribbon cables.
      • Ribbon cables are secured with tape. Do not force the cables out of their sockets.
      • Remove the screen.
Joseph Hazel
crwdns2935283:003/24/17crwdne2935283:0
353 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S8-G4, Valliere Spring 2018 crwdns2935289:0UMass Dartmouth, Team S8-G4, Valliere Spring 2018crwdne2935289:0
UMASSD-VALLIERE-S18S8G4
crwdns2935297:048crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,859
