Use this guide to replace the home button in your HP ElitePad 900.
Unscrew the two 2.8mm Phillips #000 screws near the power connector.
Use a suction cup to pull the display assembly up.
Use the tip of a spudger to disconnect the two display ZIF connectors.
Remove the two 2.4mm Phillips #000 screws.
Lift metal bracket along with blue connector.
