HP EliteOne 800 G3 RAM Replacement
crwdns2869540:0crwdne2869540:0: 559
7
43
140
559
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931273:0crwdne2931273:0
crwdns2944444:0crwdne2944444:0
crwdns2944446:0crwdne2944446:0
This guide is meant to show you how to replace/upgrade the RAM.
    1. HP EliteOne 800 G3 RAM Replacement, Removing the Stand: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteOne 800 G3 RAM Replacement, Removing the Stand: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteOne 800 G3 RAM Replacement, Removing the Stand: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Place the computer down on a flat surface with the screen facing down.
      • Push the locking mechanism up, then pull up from the middle of the stand and keep rotating towards the top of the computer, about halfway; pull up, and it should come loose.
    2. HP EliteOne 800 G3 RAM Replacement, Removing the backplate: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteOne 800 G3 RAM Replacement, Removing the backplate: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteOne 800 G3 RAM Replacement, Removing the backplate: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Push up on the little inserts until you hear a popping sound on both sides.
      • Use one of the opening picks to slowly and carefully pry up and move around the side of the computer. You will hear clicking sounds as you do so.
      • Do not put too much pressure or you could break the clips.
      • Once all the sides of the back plate have lifted up, you can then pull up and remove it.
    3. HP EliteOne 800 G3 RAM Replacement, Removing the old ram: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteOne 800 G3 RAM Replacement, Removing the old ram: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteOne 800 G3 RAM Replacement, Removing the old ram: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the ram bay to the left of the optical drive.
      • Remove the locks that hold in each ram dimm in place by pushing outwards on them and up.
      • Slowly wiggle and lift the ram module at the angle that it pops up at.
      • Do note, this step and the next applies for both ram modules, not just one.
    4. HP EliteOne 800 G3 RAM Replacement, Installing your new ram: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteOne 800 G3 RAM Replacement, Installing your new ram: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Make sure the ram module lines up with the little tab at the bottom of the slot!
      • To install your new ram, place your ram module into the ram slot at the same angle we took it out of. It should easily slide into place if at the right angle.
      • Then slowly press the ram module down until both locks on each side click into place.
      • This computer uses DDR4 SODIMM ram @ 2400MHZ. Only works up to 32GB total. For example - 2 16gb modules in each slot.
To reassemble your device, put the back plate back on and gently press on each side until you hear a click. Some sides might need a little bit more pressure than the rest (But still not very much), specifically the side with the optical drive.
Axzerax
crwdns2935283:011/28/25crwdne2935283:0
124 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 43
crwdns2936753:030crwdne2936753:0 140
crwdns2959996:0crwdne2959996:0 559
