HP EliteOne 800 G1 Fan Assembly Replacement
  1. HP EliteOne 800 G1 Fan Assembly Replacement, Removing the Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteOne 800 G1 Fan Assembly Replacement, Removing the Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteOne 800 G1 Fan Assembly Replacement, Removing the Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place computer with the screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 Fan Assembly Replacement, Removing Stand: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteOne 800 G1 Fan Assembly Replacement, Removing Stand: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press locking latch on the bottom of the base of the stand.
    • Pull the plastic cover off of the stand.
  3. HP EliteOne 800 G1 Fan Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteOne 800 G1 Fan Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx T15 driver and stick it through the holes on the stand in order to remove the two 12mm screws on the back of the main unit.
    • Tilt stand and lift up to remove it.
  4. HP EliteOne 800 G1 Fan Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteOne 800 G1 Fan Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx T15 driver to remove the single 10mm screw on the back panel.
    • Pull the back panel toward the bottom of the device to remove it.
  5. HP EliteOne 800 G1 Fan Assembly Replacement, Fan Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect these two power connectors on the motherboard, one connector is white and the other is black. You can identify the correct wires by their braided colors: red, yellow, blue, and black.
  6. HP EliteOne 800 G1 Fan Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteOne 800 G1 Fan Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx T15 driver to remove the three 6mm screws surrounding the fan assembly.
    • Pull the fan assembly up from the case to remove it.
crwdns2935229:05crwdne2935229:0
Michael Ewing
crwdns2935283:010/01/15crwdne2935283:0
1,071 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-24, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 1-24, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S1G24
crwdns2942667:0crwdne2942667:0 7,015
