HP EliteBook Folio 1020 G1 Display Replacement
  1. HP EliteBook Folio 1020 G1 Display Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a TR8 Torx screwdriver to remove:
    • Six 5.3 mm screws
    • Four 3.3 mm screws
  2. HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a nylon spudger to gently pry the lower case up and off.
  3. HP EliteBook Folio 1020 G1 Display Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook Folio 1020 G1 Display Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull and free the battery's bundled cable connector that leads from the battery to the motherboard.
  4. HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to unscrew and remove the six 4 mm screws that secure the battery.
  5. HP EliteBook Folio 1020 G1 Display Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook Folio 1020 G1 Display Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove eight 4.6 mm screws shown in the circles using Phillips #0.
  6. HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the keyboard connections from the motherboard.
    • Disconnect by lifting the underside of the white tabs with a spudger.
  7. HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect circled terminals.
  8. HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the boxed tabs in the photo by pulling the white support edges backward with a pair of tweezers.
  9. HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull on the black pull tab on the top of the connector.
    • Remove both wires going to the top of the Wi-fi card using the tweezers.
  10. HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the now disconnected motherboard from the side shown in image 1.
    • This side must be lifted to avoid damaging the ports.
    • The disconnected motherboard (aside from the port removed in step 12) is shown in image 2.
  11. HP EliteBook Folio 1020 G1 Display Replacement, Display: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook Folio 1020 G1 Display Replacement, Display: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook Folio 1020 G1 Display Replacement, Display: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To release the display frame from the lower frame, remove:
    • Six 4.1 mm screws using Phillips #0.
  12. HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the screen is separated from the bottom frame, use a plastic opening tool to remove the bottom trim from the screen.
  13. HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the iOpener and spudger, work around the screen bezel to remove it.
  14. HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the screen, remove:
    • Four 2.2 mm screws using Phillips #0.
  15. HP EliteBook Folio 1020 G1 Display Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift display from the frame.
Steven Duke
crwdns2935283:003/28/23crwdne2935283:0
127 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-1, Harley Spring 2023 crwdns2935289:0IUPUI, Team 2-1, Harley Spring 2023crwdne2935289:0
IUPUI-HARLEY-S23S2G1
crwdns2942667:0crwdne2942667:0 376
