crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Flip the laptop over so the model stickers face the ceiling.
Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
The screw on the far left middle, under the card cover, is a longer screw.
Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry back off.
Use the Phillips #0 screwdriver to remove the 3.3mm screw on the WiFi card.
Disconnect the coaxial cables wires from the WiFi card.
Thank you, my HP Elitebook 850 G3 had a faulty WiFi module, it would only turn on for a second and turn off all the time in Windows 10. Tried everything inc latest drivers and clean W10 install. This guide made it easier than I thought. Replaced WiFi module with a new ordered spare and it works perfectly now.
