This guide will show you how to replace the display assembly for an HP EliteBook 840 G7
To know if you have a bad screen signs include: Large crack in screen, no response, dim light, large rainbow lines and dots.
Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
Remove the back cover to expose the hardware.
Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
Remove the connector that connects the battery to the motherboard.
Lift up the battery with you hands or tools.
Pull up to remove the two coaxial Wi-Fi card connectors.
Pull upwards on the display connector to remove.
Pull or push to remove the bundled cable connector.
Pull upwards to remove the webcam connector.
Once you've disconnected all cables from their sockets, gently move them to the top of the laptop.
Use your Phillips # 1 screwdriver to remove the four 1.2 mm screws.
Use your Phillips # 1 screwdriver to remove the two 1.2mm screws.
Open the laptop to a 90 degree angle.
Slide the display hinges away to remove the display assembly.
