HP EliteBook 840 G3 SSD Replacement
    • As always:
    • Unplug the power cord, turn off and remove the battery.
    • Turn the notebook over and remove the Gimmi covers with a small screwdriver.
    • Now unscrew all 9! screws (see arrow) and carefully loosen the lower shell.
    • Now install the new M.2 SSD and fasten it with the small screw (arrow).
    • Now plug the new hard drive into the appropriate connector.
    • Tighten the two screws.
    • Close the notebook with the bottom shell and make sure that everything clicks into place nicely.
    • Screw everything back together and press the small rubber covers tight.
    • Insert the battery.
    • Turn on the device.
    • Reinstall Windows or format the new hard drive if you installed it as an add-on hard drive.
Work the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Robert ts
crwdns2935283:008/09/21crwdne2935283:0
172 crwdns2915208:0crwdne2915208:0
Buenas tardes tengo una hp 840 g3 no me da imagen la pantalla
john dorante - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 126
crwdns2942667:0crwdne2942667:0 3,098
