This guide shows how to de‑route the cables on the edge of the fan in your HP EliteBook 840 Aero G8 laptop.
Save your work, fully shut down your laptop, and unplug all cables.
Use a Phillips screwdriver to fully loosen (but not remove) the five captive screws securing the bottom cover.
Position your laptop so the rear edge (with the screen hinge) is closest to you.
Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
Use your spudger to pry up the cover to release the clip securing it.
Leave the spudger inserted under the bottom cover for the next step.
Slide your spudger along the rear edge toward one of the corners to release the rear edge clips.
Rotate your spudger around the corner and up the edge to release the clips securing the short edge of the cover.
Reinsert the flat end of a spudger near the ELITEBOOK text.
Repeat the previous step for the other side of the cover to release the remaining clips.
Lift and remove the bottom cover.
Position your laptop so the front edge (opposite the screen hinges) is closest to you.
Use the point of a spudger or your fingernail to push on alternating sides of the battery's sliding connector to walk it completely out of its socket.
Slide an arm of a pair of angled tweezers under the metal neck of one of the coaxial connectors on the WLAN (Wi-Fi) module, located just below the fan.
Lift straight up to disconnect the cable.
Repeat to disconnect the second connector.
Use tweezers to hold a connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again. Don't use excessive force.
Use your fingers to grip the plastic pull tab on the right display cable press connector, below the fan.
Pull straight up to disconnect the connector.
Use tweezers or your fingers to peel up the cable tape near the right side of the fan.
Use your fingers to pull the display cable and two coaxial cables out from their clips on the right side of the fan.
