Use this guide to replace your battery in your HP EliteBook 840 Aero G8 laptop. If batteries are faulty, your computer will not maintain a charge, and perform sub optimally. Keep in mind the potential hazard of electrical shock when handling the battery.
Use a JIS #0 screwdriver to unscrew the three 6.73 mm case retention screws.
Use a JIS #0 screwdriver to unscrew and remove the two 8.76 mm screws.
Use the Halberd Spudger to remove the cable running along the bottom of the battery
Disconnect the cable connected the battery to the motherboard
Use a JIS #0 screwdriver to unscrew the four 7 mm screws that secure the battery.
Slide the battery out of the clips to remove it from the laptop.
