HP EliteBook 820 G3 Keyboard Replacement
  1. HP EliteBook 820 G3 Keyboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 820 G3 Keyboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eleven 3 mm screws with a Phillips #00 screwdriver.
    • Keep track of where the screw covers were attached to as there are four different sizes.
  2. HP EliteBook 820 G3 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 820 G3 Keyboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the SD card blank and the single 3 mm screw beneath it using a Phillips #00 screwdriver.
    • Lift off the back cover with your hands.
  3. HP EliteBook 820 G3 Keyboard Replacement, Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 820 G3 Keyboard Replacement, Keyboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 3.4 mm keyboard screws found near the fan and on top of the hard drive using a Phillips #00 screwdriver.
  4. HP EliteBook 820 G3 Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 820 G3 Keyboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 820 G3 Keyboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an iFixit opening pick to gently pry open the top of the keyboard.
    • Gently pull the keyboard up until you can see the three ribbons under the keyboard.
  5. HP EliteBook 820 G3 Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 820 G3 Keyboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 820 G3 Keyboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up the latch holding down the ribbon and pull the ribbon out once it is lifted.
    • Repeat for all three of the ribbons.
    • The white ribbon (left ribbon) sometimes does not come with a new keyboard. You may need to detach it and add it to the replacement if necessary.
Caleb Morales
crwdns2935283:008/25/22crwdne2935283:0
184 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-1, Class Fall 2022 crwdns2935289:0Gateway, Team 1-1, Class Fall 2022crwdne2935289:0
GCC-CLASS-F22S1G1
I did this, it won’t stay in.
Serial Action - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,781
