How to replace the battery of a HP EliteBook 745 G4 laptop. The images and information in this guide were taken from this computer's service manual.
Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
Disconnect the power from the computer by unplugging the power cord from the computer.
Disconnect all external devices from the computer.
Turn the computer upside down on a flat surface.
Remove the 10 rubber plugs from the bottom cover.
Remove the SD card blank from the bottom cover.
Remove the 10 Phillips PM2.5x5.0 screws in the following order.
After you remove the PM2.5×5.0 screws, remove the PM2.0×7.0 screw.
Pry up on the top (near the display hinge) of the bottom cover to disengage it from the computer. Consider using a spudger.
Loosen the two captive screws and remove the battery from the computer
To replace the battery & reassemble your device, follow these instructions in reverse order.
crwdns2935229:05crwdne2935229:0
super leicht
you forgot to put the instructions for after the battery is installed when you boot it up You’ll get non-HP battery detected asking you to press enter on every boot. How is this problem fixed?
Gilt auch für 745 G3, danke.
