HP EliteBook 1050 G1 Keyboard Panel Replacement
  1. HP EliteBook 1050 G1 Keyboard Panel Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 1050 G1 Keyboard Panel Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 5.5mm screws with a Torx T8 driver.
    • Remove the five 8.7mm screws with a Torx T8 driver.
    • Remove the two 6.6mm screws with a Torx T8 driver.
    • Pry open the backplate with a Jimmy.
  2. HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 1.9mm screws from the SSDs with a Phillips #0 driver.
    • Disconnect the two PCIe SSDs by sliding them out of each port.
  3. HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the clips on either side of the RAM chip away from each other using your fingers.
    • As you pry apart the clips, the RAM should pop up to rest at an angle to the motherboard.
    • Slide the RAM chips out of their respective slots.
  4. HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove eight 4.5 mm screws from the battery with a Phillips #1 screwdriver.
    • Disconnect the white tipped battery cable from the motherboard.
  5. HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 4.5mm screws from the fan assembly using a Phillips #00 screwdriver.
    • Unscrew four 3.6mm screws from the heatsink assembly with a Phillips #00 screwdriver.
    • These "captive" screws are connected to the heatsink and will not detach from it.
    • Remove the fan assembly.
  6. HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the seven ZIF connecters from the motherboard by flipping up the black switches with a spudger and pulling out the cables.
  7. HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two 1.9mm screws from the display cable bracket using a Phillips #00 driver.
    • Remove the two connectors on the right side gently.
    • Remove the connector on right side of motherboard.
    • Remove the three 4.5mm screws using a Phillips #00 driver and remove the bracket.
    • Remove the two coaxial cables.
  8. HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 3mm screws using a Phillips #00 driver.
    • Remove the motherboard by lifting it up and out of the case.
  9. HP EliteBook 1050 G1 Keyboard Panel Replacement, Keyboard Panel: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 1050 G1 Keyboard Panel Replacement, Keyboard Panel: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 1050 G1 Keyboard Panel Replacement, Keyboard Panel: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back the black cover on the keyboard.
  10. HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all 52 screws from the keyboard panel using a Phillips #000 screwdriver.
  11. HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 1050 G1 Keyboard Panel Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the keyboard panel from the laptop.
Ming-chin Wu
crwdns2935283:009/20/21crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team 1-3, Eggleston Fall 2021 crwdns2935289:0The Citadel Military College of South Carolina, Team 1-3, Eggleston Fall 2021crwdne2935289:0
CMCSC-EGGLESTON-F21S1G3
crwdns2942667:0crwdne2942667:0 1,172
