The screen is one of the most commonly damaged components of the HP Elite x2 1012 G2. Additionally, this guide is an important prerequisite to all other repairs on this device. Thankfully, removal and repair of the screen is relatively easy.
Orient the device so the back is facing you, with the kickstand up.
Remove the six 3mm Torx T5 screws underneath the kickstand.
Turn the device over so the screen is facing you.
Place a suction cup firmly onto a corner of the screen.
Lift up gently until you see the screen separate from the casing.
Repeat this process for all four corners.
Lift the screen up and off of the device.
Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
Remove the screen by gently lifting it off of the device.
crwdns2935229:05crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Where can I purchase a screen for the HP Elite x2 1012 g2?
just completed this, VERY surprising to find a HP product with an easy install
Just finished a repair and very easy to do. Thank you!!
The touch stopped working after the replacement. Any suggestions?
I replaced my screen and upon turning the device on I have a black screen. Already made sure connections are all attached correctly. Tried hard reset with power and volume button down for 15 seconds. A bad new screen? Any other ideas?
