Lift the prop stand approximately 140 degrees from its home position to expose two T5 Torx head screws.
Use the T5 Torx bit to remove both screws from the prop stand pivot points.
Gently pull the stand away from the device until you can lift the prop stand away from the device.
I broke my stand from where did i get my stand
