Batteries are often the first components to wear out in electronic devices and as a result are a common problem. A dead battery can be frustrating, but fortunately replacing the battery on the HP Elite x2 1012 G2 is quick and easy.
Orient the device so the back is facing you, with the kickstand up.
Remove the six 3mm Torx T5 screws underneath the kickstand.
Turn the device over so the screen is facing you.
Place a suction cup firmly onto a corner of the screen.
Lift up gently until you see the screen separate from the casing.
Repeat this process for all four corners.
Lift the screen up and off of the device.
Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
Remove the screen by gently lifting it off of the device.
Orient the device so that the battery is closest to you.
Remove all six Phillips 3 mm screws around the battery by rotating in the counterclockwise direction with a Phillips screwdriver.
Remove the battery's connector by pushing both sides of the tab towards yourself with a plastic opening tool.
crwdns2935229:017crwdne2935229:0
how do you test the battery? what voltage should it be maintaining?
Bien tout en image
Hi, after the replacement battery
toch not working, help pls?
The first "Foil-Connector" in step 5 is for the Touch Feature. Make sure it fits propper!
Anselmbe -
PC not coming on, also not charging.
