HP Elite X2 1013 G3 Solid State Drive Replacement
  1. HP Elite X2 1013 G3 Solid State Drive Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Solid State Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elite X2 1013 G3 Solid State Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Solid State Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elite X2 1013 G3 Solid State Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Solid State Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elite X2 1013 G3 Solid State Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Solid State Drive Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Solid State Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery out of the housing.
  7. HP Elite X2 1013 G3 Solid State Drive Replacement, Solid State Drive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the device is powered off and the battery is removed before continuing!
    • Using the Phillips #00 Screwdriver, remove the single indicated screw.
  8. HP Elite X2 1013 G3 Solid State Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently tilt the drive upward, then firmly pull it out from the motherboard.
    • Pay attention to the orientation of the SSD. Trying to put your replacement SSD in the wrong way could damage the part or the connector.
Kory Haydon
crwdns2935283:004/18/19crwdne2935283:0
259 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S9-G12, Maness Spring 2019 crwdns2935289:0Cal Poly, Team S9-G12, Maness Spring 2019crwdne2935289:0
CPSU-MANESS-S19S9G12
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 3,542
