HP Deskjet D1660 Springs Replacement
  1. HP Deskjet D1660 Springs Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back two 14.0 mm Torx #10 screws.
  2. HP Deskjet D1660 Springs Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. HP Deskjet D1660 Springs Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  4. HP Deskjet D1660 Springs Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Deskjet D1660 Springs Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Deskjet D1660 Springs Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
  5. HP Deskjet D1660 Springs Replacement, Ink Cartridge Rail: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Deskjet D1660 Springs Replacement, Ink Cartridge Rail: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 13.0 mm Torx #10 screws found on top of the frame.
    • Remove the four 9.0 mm Torx #10 smaller screws.
  6. HP Deskjet D1660 Springs Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Deskjet D1660 Springs Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the rail carefully as a strip and motor will be connected to the bottom part of the printer.
    • Now detach the white strip and wires by gently lifting them up.
  7. HP Deskjet D1660 Springs Replacement, Springs: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Deskjet D1660 Springs Replacement, Springs: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the springs. They will be on the side of the metal frame.
    • Using the tweezers, grab the loop of the spring that is connected to the bar.
    • Remove the spring by lifting the loop.
Justin Taiki Fukada
crwdns2935283:001/25/14crwdne2935283:0
912 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-41, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 1-41, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S1G41
crwdns2942667:0crwdne2942667:0 1,323
