When no paper is being dispensed from your printer, it is enough to drive you mad. If this is driving you mad, the Paper Roller Motor may not be driving anything at all. Save the stress and follow this guide to replace the Paper Roller Motor.
Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Locate and remove the two flat ribbon connectors which connect the circuit board to the other printer components.
Locate and remove the three multicolored wire connectors which connect the circuit board to the other printer components.
Remove the top two 13mm screws using a screwdriver with the T10 torx bit.
Remove the bottom 9mm screw using a screwdriver with the T10 torx bit, and remove the plug port circuit board.
Locate the paper control sensor.
Locate and unplug the connector which connects the sensor board to the main circuit board.
Locate and remove the 8mm screw with a screwdriver and the T10 torx bit, then remove the paper control sensor board.
Remove the two 13mm screws with the screwdriver and a T10 torx bit.
Remove the one 9mm screw with the screwdriver and a T10 torx bit.
Lift the entire ink dispenser assembly out of the printer.
Remove the two 5mm screws which hold motor in place.
Remove the belt from the round motor gear, then remove the ink carriage motor.
Remove the two 13mm screws which hold the paper roller motor frame in place.
Lift the roller arm and motor frame out enough to reach the belt and motor screws.
Unscrew the upper 4 mm screw which holds the motor in the metal frame. This allows the motor to slide enough to loosen the belt.
Remove the belt from the motor gear.
Remove the remaining 4mm screw from the motor, then take the motor out.
