HP Compaq nc6400 Screen Replacement
    1. HP Compaq nc6400 Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn off and unplug laptop.
    2. HP Compaq nc6400 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the battery lock below the battery labeled one.
      • Slide the lock all the way to the left to release the left lock of the battery.
    3. HP Compaq nc6400 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the lock labeled two at the bottom right corner below the battery.
      • Slide and hold the lock to the left.
    4. HP Compaq nc6400 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once both the battery locks are unlocked, slide the battery out to remove.
    1. HP Compaq nc6400 Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 1.2mm Philips #1 screws attaching the plastic cover to the monitor.
      • The screws may have a small, black plastic cover that lays flush with the screen. Remove these using a pointed tool such as the spudger or philips head screwdriver by prying them out.
    2. HP Compaq nc6400 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 1.2 Philips #1 screws attaching the face plate to the body.
    3. HP Compaq nc6400 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq nc6400 Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq nc6400 Screen Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pry up the plastic screen cover using a pry tool.
      • Keeping the pry tool under the trim, slide it around the entire screen until the the cover has completely detached from the base.
      • You might need to slide the display clip on the top of the screen in order to fully remove the plastic cover.
    4. HP Compaq nc6400 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq nc6400 Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 1.2 Philips #1 screws holding down the sensor board at the bottom of the monitor.
    5. HP Compaq nc6400 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the right-most 1.2mm Philips #1 screw on the bottom of the monitor.
    6. HP Compaq nc6400 Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq nc6400 Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Without lifting the bottom of the monitor, gently flip the screen and lay it face down on the keyboard.
    7. HP Compaq nc6400 Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq nc6400 Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the tape holding down the video cable to the monitor.
      • Gently pull out the video cable from the monitor.
    8. HP Compaq nc6400 Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq nc6400 Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the monitor's power cable from the sensor board.
      • This is the cable on the farthest right of the sensor board.
    9. HP Compaq nc6400 Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq nc6400 Screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once all cables attaching the casing to the monitor have been disconnected, remove the entire screen from the computer and lay it on a flat surface.
      • Remove the four 1.2 Philips #1 screws attaching the bezel to the right side of the monitor.
      • Attach bezel to replacement screen.
Luis Vazquez
crwdns2935283:009/24/13crwdne2935283:0
401 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-6, Forte Fall 2013 crwdns2935289:0Cal Poly, Team 14-6, Forte Fall 2013crwdne2935289:0
CPSU-FORTE-F13S14G6
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 110
crwdns2942667:0crwdne2942667:0 6,072
