HP Compaq nc6400 RAM Replacement
    1. HP Compaq nc6400 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn off and unplug laptop.
    2. HP Compaq nc6400 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the battery lock below the battery labeled one.
      • Slide the lock all the way to the left to release the left lock of the battery.
    3. HP Compaq nc6400 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the lock labeled two at the bottom right corner below the battery.
      • Slide and hold the lock to the left.
    4. HP Compaq nc6400 RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once both the battery locks are unlocked, slide the battery out to remove.
    1. HP Compaq nc6400 RAM Replacement, RAM: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq nc6400 RAM Replacement, RAM: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the 1.2 Philips #1 screw holding down the RAM cover to the body.
    2. HP Compaq nc6400 RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the screw is removed, use a spudger to pry open the case covering the RAM chip.
    3. HP Compaq nc6400 RAM Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq nc6400 RAM Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a plastic opening tool to pull back the white clip holding the RAM chip in place.
      • Once the plastic opening tool has disengaged the clip from the RAM chip, keep the plastic opening tool locked into place.
    4. HP Compaq nc6400 RAM Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • With a second plastic opening tool,repeat the above process
      • After both plastic opening tools have been locked in place, the RAM chip should pop out about 1/4 of a inch.
    5. HP Compaq nc6400 RAM Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq nc6400 RAM Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The RAM chip is susceptible to static electricity. Before grabbing the RAM chip, make sure you have discharged the electricity from your hands by touching a metal surface other than your computer.
      • Grab the RAM chip with your thumb and index finger
      • Carefully pull the RAM chip out
crwdns2935229:05crwdne2935229:0
Luis Vazquez
crwdns2935283:009/24/13crwdne2935283:0
401 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-6, Forte Fall 2013 crwdns2935289:0Cal Poly, Team 14-6, Forte Fall 2013crwdne2935289:0
CPSU-FORTE-F13S14G6
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 119
crwdns2942667:0crwdne2942667:0 5,055
