HP Compaq nc6400 Bluetooth Module Replacement
    1. HP Compaq nc6400 Bluetooth Module Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn off and unplug laptop.
    2. HP Compaq nc6400 Bluetooth Module Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the battery lock below the battery labeled one.
      • Slide the lock all the way to the left to release the left lock of the battery.
    3. HP Compaq nc6400 Bluetooth Module Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the lock labeled two at the bottom right corner below the battery.
      • Slide and hold the lock to the left.
    4. HP Compaq nc6400 Bluetooth Module Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once both the battery locks are unlocked, slide the battery out to remove.
    1. HP Compaq nc6400 Bluetooth Module Replacement, Bluetooth Module: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the computer top down and locate the second to-the-right 1.2 Philips #1 screw in the bottom-left corner.
      • Remove the screw.
    2. HP Compaq nc6400 Bluetooth Module Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq nc6400 Bluetooth Module Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq nc6400 Bluetooth Module Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the right side of the Bluetooth Module cover upwards.
      • Slide the spudger under the lifted case, and slide it left towards the closed end. The case will pop open and be removed from the compartment.
    3. HP Compaq nc6400 Bluetooth Module Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the Bluetooth Module after removing the cover.
      • Using the spudger, push the module to the right (i.e. towards the screw hole).
      • Pull outwards and remove bluetooth module and wire from casing.
    4. HP Compaq nc6400 Bluetooth Module Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq nc6400 Bluetooth Module Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once the module and wire are completely outside of the casing, gently pull apart the wire from the module clip.
Yoshitake Yamada
crwdns2935283:009/30/13crwdne2935283:0
266 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-6, Forte Fall 2013 crwdns2935289:0Cal Poly, Team 14-6, Forte Fall 2013crwdne2935289:0
CPSU-FORTE-F13S14G6
Hi,
My HP nx9420 did not have the Bluetooth. I wish to install one. I got one from my old HP nx9420. it Part Number is 397922-001 but the actual laptop says it requires the 409993-001 are these module the same ?
thanks
Alain
Alain Bastien - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 106
crwdns2942667:0crwdne2942667:0 2,822
