This guide we are going to remove the wireless card by removing the RAM cover and then pulling out the wireless card.
On the underside of the battery, there is lock that keeps the battery in place. Using your finger, slide the battery lock to unlock the battery. When you have unlocked it, just lift the battery to remove it.
Remove the three M2.5x5 mm Phillips screws securing the memory case.
Using a plastic opening tool, insert it alongside any openings on the case. Lift and slide the tool to remove the case.
Locate the the Wireless Card located next to the RAM chips.
Remove the single M2.5x3 mm Phillips screw.
Using your hands, gently remove the cables connected to the wireless card.
